ramjet73
Jun 12, 2015Aspirant
Seagate ST3000DM001 7200.14 Compatibility and Warranty
I recently had some corruption problems with my ReadyNAS Ultra 4 and with the help of Netgear technical support it is back up and running in a somewhat patched mode. Their recommendation is to upgrade the current drives (Seagate ST2000DL003-9VT166), since they are not supported with the CC32 firmware and can't be upgraded to a higher level, then do a factory reset and restore my data. Since my Ultra 4 has been running for about 4 years with only minor problems until my admin password got corrupted twice recently the upgrade is an unexpected expense so I am trying to do it with as little cost as possible.
In reviewing the compatibility list for my model (http://kb.netgear.com/app/answers/detail/a_id/20641) I noticed that the Seagate ST3000DM001 is included and I already have two of those drives in a Mediasonic HFR2-SU3S2 4-bay enclosure configured as RAID1 and I ordered two more so I could replace the current drives in the Ultra 4. At first I was concerned about the one year warranty shown in the Netgear compatibility list but it turns out the warranty is actually two years, at least on current models, and even though it is designed primarily as a desktop drive Seagate shows it as certified in their compatibility list for business NAS (http://www.seagate.com/files/www-content/support-content/external-products/business-storage/_shared/docs/nas-certified-drives-sc522-2-1306us.pdf) although the NAS model used to certify it is not identified.
I'm certainly not arguing that the ST3000DM001 should be preferred over the WD Red or Seagate Constellation drives for NAS configurations but it makes me feel better to know that the warranty is actually two years as opposed to the one year specified in the Netgear compatibility list and that Seagate considers it certified for NAS applications. I plan to use my four Seagate ST2000DL003-9VT166 drives in the Mediasonic enclosure and hope that is not as sensitive to the drive firmware issues as my Ultra 4.
Perhaps this information will be helpful to users that are on a tight budget and might be able to afford the ST3000DM001 drives but not the more expensive "NAS" drives for an upgrade or new installation.
- StephenBGuru - Experienced UserI've also been very happy with the WDC red drives - currently I am running eight WD30EFRX, one WD20EFRX and two WD60EFRX. I started using them in 2012 and so far have had one failure (replaced under warranty), and never had a DOA.
