nicho2016
Sep 09, 2016Aspirant
Seagate ST31500341AS-CC1H on ReadyNAS Pro Pioneer Edition(1YA59CRE00137)
I am running the above data storage with six drivers of Seagate ST2000DM001-1CH164. But one driver broken. Can I use one Seagate ST31500341AS-CC1H to replace the broken one?
Thanks,
Nicho
Unfortunately no. You need a 2 TB drive, and the ST31500341AS is only 1.5.
I suggest either a WD20EFRX or a ST2000VN000. Both are intended for NAS use.
- nicho2016Aspirant
Thanks StephenB.
Can ST2000VN000 with any firmware be used on ReadyNAS Pro Pioneer Edition(1YA59CRE00137)?
It should be fine (other folks have used in in OS 4.2 systems and it is on the HCL for the Pro Pioneer). The WD20EFRX certainly works (I'm a WD guy myself).
Seagate NAS HDD ST2000VN000 2 TB 6Gb/s 64 MB Yes 3
