zimmfor
May 22, 2019Aspirant
Setting up ReadyCLOUD on ReadyNAS Account permission issues
Hi Everyone,
When I try to setup ReadyCloud on our new ReadyNAS it says a local user account with the same username already exists use a different account. I want to use the account I am trying...
- May 23, 2019
Thank you for the update, I will come up with an alternative plan.
Sandshark
May 23, 2019Sensei
Unfortunately, there is no simple work-around. Netgear has chosen that a ReadyCloud user and a local user cannot be the same. They must have separate logins and separate home shares.
The only other option is to go a different route for remote access, using a VPN instead of ReadyCloud.
zimmfor
May 23, 2019Aspirant
