100andthirty
Aug 12, 2012Aspirant
Single click very 10 minutes or so
My ReadyNAS DUO mk 1 with two Samsung 1TB drives is exhibiting some odd sysmptoms whilst continuing to work. I don't normally have it switched on but use it for back up of vital material - images and ...
Aug 13, 2012Guru - Experienced User
You might remove the drives (with the unit powered down, but plugged in) - and see if the clicking stops.
