markwoll
Feb 12, 2014Guide
sizing 516 volume/raid choice
Since the os6 seems to have stabilized I am shopping for a 516. I have a couple of questions about volume /raid configurations. If I go with a raid 6 will I have the capacity of 3 drives for volumes...
mdgm-ntgr
Feb 19, 2014NETGEAR Employee Retired
Put one disk in NAS, update to 6.1.6, verify update completed successfully, power down, put all disks in and do a factory default.
To use RAID-6 you will need to disable X-RAID, delete the volume, create a new RAID-6 volume and if you want you can then turn X-RAID back on.
