kevinngeorgia's avatar
Jan 13, 2012
Sliding Rails for 3100
I'm about to replace a 1100 with a 3100 but don't know if it uses the same rackmount sliding rails. I can't find any specific rails for the 3100...
Thanks for any help,
Kevin
  • Thanks for the reply from the product description it sounds like an optional product not part of the package.. good to know they come with it..
    Kevin
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    "Optional spare part" i.e. spare part you can purchase to replace what is included in the package if it fails. Some people like to have a spare part on hand to minimise downtime. Sliding rails are not a component that's likely to fail so unless you're managing a huge number of units you're unlikely to want a spare.
ProSupport for Business
