solanagraphics
Mar 23, 2014Aspirant
Smells Like Burning - Used Incorrect Power Supply
Hi, I had a VERY unfortunate incident a few weeks ago when I was relocating my ReadyNas Duo v2 from my home to a new office. I had moved several other electronic devices as well and when it came ti...
mdgm-ntgr
Mar 23, 2014NETGEAR Employee Retired
If you have a Linux machine it is easy to mount the volume. You could possibly try running a Linux VM (e.g. Debian or Ubuntu) in VirtualBox if you want.
Just need packages such as mdadm and lvm2 installed (these may already be pre-installed depending on what OS you choose to use).
Something like
Something like
# apt-get update
# apt-get install mdadm lvm2
# mdadm --assemble --scan
# vgscan
# vgchange -a y c
# mount -o ro /dev/c/c /mnt
