Maxime000
Nov 25, 2011Aspirant
Software with ReadyNAS Duo V2 (RND2000-200xxx)
Hi all, I'd like to know if there is still a software bundled with the ReadyNAS Duo v2? The v1 had something called NTI Shadow... If there is such software, is it Maco OS X and Windows compatible? a...
mdgm-ntgr
Feb 13, 2012NETGEAR Employee Retired
It should probably be on the CD, I think. Work with support and they should be able to get you a download link for the software.
The software should detect the NAS and that you have a license for the software.
