Maxime000
Nov 25, 2011Aspirant
Software with ReadyNAS Duo V2 (RND2000-200xxx)
Hi all, I'd like to know if there is still a software bundled with the ReadyNAS Duo v2? The v1 had something called NTI Shadow... If there is such software, is it Maco OS X and Windows compatible? a...
ColonelPanik
Feb 13, 2012Aspirant
Support doesn't even know it's supposed to be bundled. I had to point them to the website with the specs. It's not on the CD. No files are hidden in Explorer either ;)
I tried downloading it from Memeo and it doesn't autodetect anything. It's a 30 day trial without a license key. Whenever my patience is high and I have the time I'll call back and ask for a supervisor or something. I've seen other posts on the forums with the same stuff going on.
