Maxime000
Nov 25, 2011Aspirant
Software with ReadyNAS Duo V2 (RND2000-200xxx)
Hi all, I'd like to know if there is still a software bundled with the ReadyNAS Duo v2? The v1 had something called NTI Shadow... If there is such software, is it Maco OS X and Windows compatible? a...
mdgm-ntgr
Feb 14, 2012NETGEAR Employee Retired
You will need to call them back and ask for your case to be escalated to a more senior representative. Refer to your existing case number (the tech support representative should have given you one).
