Maxime000
Nov 25, 2011Aspirant
Software with ReadyNAS Duo V2 (RND2000-200xxx)
Hi all, I'd like to know if there is still a software bundled with the ReadyNAS Duo v2? The v1 had something called NTI Shadow... If there is such software, is it Maco OS X and Windows compatible? a...
ColonelPanik
Feb 14, 2012Aspirant
mdgm wrote: You will need to call them back and ask for your case to be escalated to a more senior representative. Refer to your existing case number (the tech support representative should have given you one).
After 10 minutes on hold and with their history of not following up on open cases I just hung up without a case #. I'll give them a call in a bit and try my luck.
