nielsblack
Jan 20, 2012Follower
Sony PDWU2 USB 3.0 XDCAM Disc Drive
Is there support for the Sony PDWU2 USB 3.0 XDCAM Disc Drive? I would like to plug in the drive, put in a disc, press a button or automatically have the disc contents copied to the NAS. Thanks,
http://pro.sony.com/bbsc/ssr/product-PDWU2/
1 Reply
- PapaBear1ApprenticeThe USB ports on the ReadyNAS are primarily intended for backing up the files FROM the ReadyNAS and restoring backups TO the ReadyNAS. You would probably be better served connecting the unit to a PC and copying the files over the Network. The ReadyNAS probably would not recognize the file format on the unit as I doubt it is FAT32, NTSF or EXT2/3.
