mn1247
Oct 16, 2011Aspirant
Spare hot-plug disk trays?
The spare hot plug trays for the NV+ seem to have been discontinued. What's going on with this? I need to buy some. Thanks Eric
PapaBear1
Oct 30, 2011Apprentice
They have probably gone to the ones with the square recessed release that came out with the NVX. They are on all the new production units for some time.
Checking the Netgear Store, they seem to be in stock for $24.99.
Of course if you are going to put a drive into the ReadyNAS only for a short period, you can also use only two screws in opposite corners. This was a trick posted by one of the Jedi as they do this when evaluating hard drives for the HCL.
