mn1247
Oct 16, 2011Aspirant
Spare hot-plug disk trays?
The spare hot plug trays for the NV+ seem to have been discontinued. What's going on with this? I need to buy some. Thanks Eric
mdgm-ntgr
Nov 01, 2011NETGEAR Employee Retired
pdizazzo wrote: Is this the same part number for the ReadyNas 1500? We just bought one and we rotate the whole set of drives offsite each week in case catastrophic failure. We just use it for backups of all of our other servers.
No. Rackmount units use a different style tray to desktop units.
SATA connectors are designed for a limited number of pulls and handling drives bare you risk damaging them without realising it. I would suggest you review your backup strategy and choose a better method.
