mn1247
Oct 16, 2011Aspirant
Spare hot-plug disk trays?
The spare hot plug trays for the NV+ seem to have been discontinued. What's going on with this? I need to buy some. Thanks Eric
mdgm-ntgr
Nov 02, 2011NETGEAR Employee Retired
You can easily put 4-8 GB of data on a USB key. Far more cost effective than using mechanical hard disks with heaps more space. I think you mean 4-8TB of data.
You may be fortunate for now, but eventually you're going to find you have a problem if you keep this up. It's not a matter of if, but when.
