Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ...
mdgm-ntgr
Oct 30, 2010NETGEAR Employee Retired
Your disks are 4k sector disks so you should have backed up all data, verified backup is good, update to 4.1.7 T48 or later (already done this so need to do it again), done a System > Config Backup, factory default (http://www.readynas.com/forum/faq.php#How_do_I_reset_the_ReadyNAS_to_factory_default%3F), restore Config Backup, restore data from backup.
Without alignment for 4k sectors you may have poor write performance.
