Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ...
mdgm-ntgr
Nov 03, 2010NETGEAR Employee Retired
Wracky wrote:
Device Boot Start End Blocks Id System
/dev/hdc1 32 4096031 2048000 fd Linux raid autodetect
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096032 5144607 524288 fd Linux raid autodetect
Partition 2 does not end on cylinder boundary.
/dev/hdc3 5144608 3907012815 1950934104 fd Linux raid autodetect
That's fine. You can see the start numbers are divisible by 8 and the first one is 32, which is what you expect to see with 4k sector alignment on Sparc ReadyNAS. Remember 512 bytes * 8 = 4k
