Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ...
goondog
Nov 04, 2010Aspirant
thanks mdgm.
i now have running 1 hitachi 2TB off the HCL and 2XSamsung F4s with 3.6T total
I plan on adding another samsung 2TB next week for a total of about 5.4TB
i factory reset the first three drives and everything looks ok but wanted to make sure i got 4K properly set up.
below is my partition log:
thanks again for all the help on the forums!
Disk /dev/hdg doesn't contain a valid partition table
Disk /dev/hdc: 2000.3 GB, 2000388448256 bytes
255 heads, 63 sectors/track, 243200 cylinders, total 3907008688 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hdc1 32 4096031 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096032 4608031 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hdc3 4608032 3906992335 1951192152 5 Extended
/dev/hdc5 4608040 3906992335 1951192148 8e Linux LVM
Disk /dev/hde: 2000.3 GB, 2000388448256 bytes
/dev/hde1 32 4096031 2048000 83 Linux
/dev/hde2 4096032 4608031 256000 82 Linux swap / Solaris
/dev/hde3 4608032 3906992335 1951192152 5 Extended
/dev/hde5 4608040 3906992335 1951192148 8e Linux LVM
Disk /dev/hdg: 2000.3 GB, 2000388448256 bytes
