Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ...
soulseeker
Nov 21, 2010Aspirant
I'm currently copying back my data on my Duo. I added samsung two 2tb-disks yesterday and they seem to run without problems. At first, I didn't do a factory reset, because I switched both disks ath the same time. Just to be safe after 1 hour when the drive was in the process of resyncing I did the reset anyway. After 10 hours the drive went into redundancy and now I am copying back my data. Looks good so far.
I didn't do any benchmarks, but currently I'm around 13-15 mb/s (with lots of small mp3-files), a bigger avi startet with 25 mb/s and went down to 18mb/s. I think before it was a little faster (25-30), but this was only a quick test.
My partition log shows:
so I hope everythings ok.
Disk /dev/hde doesn't contain a valid partition table
Disk /dev/hdc: 2000.3 GB, 2000388448256 bytes
255 heads, 63 sectors/track, 243200 cylinders, total 3907008688 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hdc1 32 4096031 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096032 4608031 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hdc3 4608032 3906992335 1951192152 5 Extended
/dev/hdc5 4608040 3906992335 1951192148 8e Linux LVM
Disk /dev/hde: 2000.3 GB, 2000388448256 bytes
