Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ...
soulseeker
Nov 23, 2010Aspirant
1. Do a backup
2. Upgrade your NAS to 4.1.7
3. Power down, add two new disks, power on
4. Use raidiator to find out the new IP-Adress
5. Although the NAS should be factory default by adding two disks (you can see that because all settings are gone), you can directly go to the system tab and do a factory default directly after Power on (I did it that way just to be sure that the correct partition alignment is used)
6. Wait until redundancy (10-12 hours)
7. Restore settings and finally data from backup
