Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ...
Mutley1
Nov 24, 2010Aspirant
Don't you have to have a gigabit network/switch for jumbo frames? Or the fact that it's going direct from the Duo to the caddy, then the gigabit switch doesn't apply?
Something is not right. I've just checked and there's approx 15 GB been copied over 12/13 hours. Going to cancel backup and...........
Just gone into frontview and got message alert. Backup job was canceled after 3 hours. "error" but no description in logs. Going to run through the share permissions and reset anything that doesn't look right to "admin and nogroup". And select jumbo frames to see if it helps with or without a gigabit switch.
peeved mutley
Just gone back into the manual and found "enable fast CIFS writes" in the performance tab. Wasn't selected so done so. Change owner ship of shares to admin and nogroup and selected "jumbo frames", although it does mention a "switch" in the description.
Lets see what happens.
peeved mutley
