Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ...
eco001
Dec 09, 2010Aspirant
Wow that was fast, but I haven't made a DOS boot disk in forever. lol I suppose a dos boot flash drive would be the way to go. Anyone know if I could get the patch to find the drive in an eSATA docking station in that environment? Otherwise, I'll hafta play musical SATA ports.
You shouldn't have to format it beforehand, but maybe afterwards. I would definitely assume, tho, that the drive gets wiped.
You must have grabbed the wrong file. It should be an executable.
NCQ is supported in ACHI only, so IDE mode is definitely not affected by this bug. I would consider ignoring the problem if I could verify the ReadyNAS is in IDE mode and not liable to change in the future.
Mutley wrote: I'm assuming take one disk out at a time, format it to Fat32 or NTFS, patch it, let it re-sync (however long that takes, a day/2days). Then whip out the other disk and repeat.
Mutley wrote: I've just downloaded the patch, which is a text file. How does one run it in dos etc..?
Samsung Support wrote: If identify commmand is issued from host during NCQ write command in the condition of
PC not external , write condition is unstable. So It can make the loss of written data.
