Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ...
eco001
Dec 10, 2010Aspirant
Mutley wrote: Silly question, but how to execute the .exe from command prompt? What's the key sequence, or just hit return....I've no idea?
mutley
Just type the name of the executable and hit return to run it. Make sure you've copied it to the root of the usb stick first. If you need to double check it's name, type "dir" (w/o quotes) at the prompt for a list of files. If there are too many files, type "dir |more" and it will paginate. The "|" character is a shifted back slash key.
hth
