Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ...
airs
Dec 10, 2010Aspirant
soulseeker wrote: i can't figure out for sure what really causes the problem but I tried the following:
1. I copied a large file on the nas
2. During the copy-job I opened frontview and in "status" I opened the smart tab several times so that the nas does a smart query on both discs. And nothing happened to the file copied. So currently I think the fix is pretty useless for readynas users.
Maybe it just let's us sleep better ;).
* This warning also applies to other tools which use IDENTIFY DEVICE to obtain drive information. The problem is not SMART related.
So it looks like the specific command is IDENTIFY_DEVICE - I'm not sure when (or if) the Readynas would issue it. Did you compare the MD5 of your test files after the copy?
