Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ...
airs
Dec 10, 2010Aspirant
Mutley wrote: Another question regarding patch procedure
Once the computer booted, it dropped me at a C:\> command prompt and I just executed the Samsung exe.
If I'm attaching disk via dock/caddy to laptop with XP, would it still be 'C:\' or be whatever xp gives hard drive i.e. "J:\" and then "filename.exe"? So I'd have to change prefix from "C:\" to "J:\"?
Or it don't matter, patch will find it's way to Samsung hard drive?
mutley
It'll find the drive, just make sure its the only SATA/IDE device connected to be safe. As for C versus J, it should drop you to C.
