Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ...
mattseattle
Dec 10, 2010Aspirant
The HD204UI was on the HCL for the Synology product line. At least till this bug cropped up then they removed it.
I'm doing a few more tests as I just had a file come up as NOT IDENTICAL so before I say for sure I'm going to do a few more tests.
Update:
I repeated the test 15 times with 2 different video files and some jpg's. Out of all the tests I had one MD5 test come back as NOT IDENTICAL. I can't replicate it so not sure what the cause was.
Update:
