Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ...
Mutley1
Dec 12, 2010Aspirant
eco001
Ooh , good idea. I wouldn't have thought of that (brain working on half cylinders). Instructions I can just about follow at the minute, ideas I'm all out of.
Is it the same procedure as the boot usb? Or even easier as it's on cd?
I suppose I'd have to copy....oh sod it. I'm gonna do the restore of the XP I think anyway. It's too cluttered. I made some real good clean setup images back in the day. Last year in fact. I'll restore one of them, see if I can access Bios, or failing do the cd.
Is the cd booter easy to do? I've had a quick look at the usb bootable website/instructions. I guess it's the same, need Dos files to make it bootable and then copy the patch.exe file onto the cd via the program.
Any other suggestions I'm missing?
I was hoping you'd be just like the sexy fox from Dollhouse. Never mind, I took a shot.
