Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ...
eco001
Dec 12, 2010Aspirant
Mutley wrote:
Is the cd booter easy to do? I've had a quick look at the usb bootable website/instructions. I guess it's the same, need Dos files to make it bootable and then copy the patch.exe file onto the cd via the program.
The theory is the same, but you have to deal with cd standards. Burning software usually comes with an easy canned routine. Go check the help file in your software. Just remember to add the Samsung utility file to the burn list. Failing that, there are numerous websites with tutorials and shared files like for the usb boot drive. Which reminds me, the dos disc will need to provide usb support in order to see the disk caddy. It should be the default, but it's something to look out for.
Mutley wrote:
I was hoping you'd be just like the sexy fox from Dollhouse. Never mind, I took a shot.
A foxy chick messing with her NAS and firmware upgrades. A very long shot, indeed!
