Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ...
eco001
Dec 13, 2010Aspirant
Mutley, your options depend upon the age and manufacturer of your laptop. Business machines usually keep those options to a minimum.
Are you sure you're using the right keystroke to enter the bios? Common ones are F2 or "del", and you often have to rapidly and repeatedly press the key at the start of boot. If you're not sure of the key, google it. If you're doing it correctly, maybe your keyboard is going flaky.
You still have the boot CD option. Did you check your burn software?
