Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ...
mattseattle
Dec 14, 2010Aspirant
The PC I bought was about $275.00 before taxes. I knew the frustration I would encounter if I tried to do it any other way so to me it was just easier to buy a PC that supports SATA. I used my USB thumb drive and used the HP program to create a bootable thumb drive and copied the Samsung patch EXE onto the thumb drive. For some reason the HP program kept hanging but finally it worked. After I was able to accomplish that I just hooked up each of my Samsung drives and ran the Samsung patch. It shows you confirmation on the screen that it's updated the firmware. After that you just go on to the next drive....
Believe me I know it's frustrating...
