Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ...
Mutley1
Dec 14, 2010Aspirant
Hi mattseattle
How long did the HP program hang for?
How long did you give hanging before you rebooted and tried again?
How many times did you go through the hang process?
How quickly did it go into a 'dos' screen when it did work properly, so I know what to expect?
And when you say you got a confirmation, I take it that would've been in the 'dos' screen? It actually says 'hdd updated'?
Probably should've done the same with a sata pc. It cost me that off of work yesterday.
