Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ...
mattseattle
Dec 16, 2010Aspirant
I'm glad you got one of the drives done. I wouldn't worry about the cable flex - just hold the drive in your hand if you need to. It only has to be connected long enough to run the Samsung patch file.
