Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ...
lazerharp
Jan 31, 2011Aspirant
shadowz wrote: Hi,
I'm having same issue as marcelser, but with X-Raid. playing any video files from the NV unit with the samsung drives will lag, stutter, or just freeze. I have another unit that has the wdc10eacs drives which does not have such issues with the same file. I've went over the config and both units have identical performance options. I'm about to take them out and return it.
Anyone having this problem with DUO? I mainly use the DUO for media streaming so it would be a disaster if this would be the case.
/L
