Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ...
neoberlin
Feb 19, 2011Aspirant
Hi everyone,
I got my ReadyNas Ultra 4 Plus two weeks ago along with two Samsung F4.
Did the firmware update as shown in this threat (thanks alot for this!).
Happy to tell you, everything is smooth so far. Partition.log shows:
Device Boot Start End Blocks Id System
/dev/sda1 64 8388671 4194304 fd Linux raid autodetect
Partition 1 does not end on cylinder boundary.
/dev/sda2 8388672 9437247 524288 fd Linux raid autodetect
Partition 2 does not end on cylinder boundary.
/dev/sda4 9437248 3907024064 1948793408+ 5 Extended
/dev/sda5 9437256 3907024064 1948793404+ fd Linux raid autodetect
Disk /dev/sdb: 2000.3 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders, total 3907029168 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
/dev/sdb1 64 8388671 4194304 fd Linux raid autodetect
/dev/sdb2 8388672 9437247 524288 fd Linux raid autodetect
/dev/sdb4 9437248 3907024064 1948793408+ 5 Extended
/dev/sdb5 9437256 3907024064 1948793404+ fd Linux raid autodetect]
Mine has a Start count of 64 (most of the partition.log in this threat have 32 as Start count), but I figure, this should be fine.
So fare anything works very smooth. Fan is very silent, hard drives are around 29/32C (my NVX with two Barracuda Seagate which are shipped with the ReadyNasNVX are usually on 40/42C, so the fan is running much louder).
Performance is very fast to stream and copy. But rsync on my LAN (600GB) took as well one day.....
So far, so good...I'm happy!
