stobby256
Sep 05, 2013Aspirant
SqueezeCentre refuses to start ReadyNAS Duo
Hi All. Just reinstalled two drives in my Duo (v1). Two old disks gave me problems and it would not start! So, all up and running, data restore tomorrrow 8) The problem I have is now with...
Sep 06, 2013Guru - Experienced User
If you reset the box, there is no squeezecentre to click on, correct? Are you meaning that you can't install the add-on?
stobby256 wrote: Nothing doing - reset to factory defaults, click on Squeezecentre and tick the box, click apply. It thinks for a minute then it unticks the box. Happens everytime!
