kidbrother1
Mar 12, 2012Aspirant
STORA drives
I'm planning to upgrade from STORA to ReadyNAS. I'm contemplating re-using the drive from the STORA. Has anyone done this successfully? If so, how did you get the data from the STORA to the R-NAS?
I think the answer is no, but are there any limitations to the RNAS that might cause me to want to keep certain data types on the STORA?
Thanks in advance.
Thanks in advance.
- mdgm-ntgrNETGEAR Employee RetiredThe disks can be reused but they will need to be wiped (so backup data first). Be sure only to use disks from the ReadyNAS HCL
My advice would probably be to simply buy new disks and transfer the data across your network.
Is the Stora still working?
What disks do you have currently? How much data is stored on the drives?
Which ReadyNAS model do you wish to migrate to? - kidbrother1AspirantThanks, I am looking at the ReadyNAS 4000. I have a single 1TB drive in the Stora and it's working great. Just don't have anywhere else to put all the data on if I pull and reformat the drive.
I think I'll probably just buy new drives to migrate.mdgm wrote: My advice would probably be to simply buy new disks and transfer the data across your network.
Which ReadyNAS model do you wish to migrate to? - PapaBear1ApprenticeKidbrother, there are three current models and one recently discontinued with the number 4000 in their model number. The first three or four letters are the key to which specific model you are talking about. They all start with RND for ReadyNAS desktop. The RND4000 v1 is the original NV+ (v1) and has been discontinued (some are still in the retail chain) and has been replaced by the RND4000 (v2) which is significantly different. The RNDU4000 is the Ultra 4, the RNDP4000 is the Pro 4. (In between those two is the Ultra 4+ with the model number RNDP400U.)
The 4000 simply means it is a four bay unit and sold diskless.
All are good units, the RNDU4000 and RNDP4000 are more flexible and have better features than the RND4000, but are also more expensive.
Welcome to the ReadyNAS forum.
