SLK-Purdue's avatar
SLK-Purdue
Luminary
Sep 22, 2020
Strange issue with migration from 102 to 312
I updated from a ReadyNAS RN102 to a RN 312.  I moved the volumes as detailed in the instructions.   Everything worked great and the new unit came up just fine.running 6.10.3.   (Nice improvement in performance!!!)
Interesting, in the service display HTTP and HTTPS are grey and can not be enabled.   (see photo)  I can access the unit via HTTP just fine.   In the log, I see the following.  I would like to be sure things are correct and also enable HTTPS and get the cert set correctly.   Any ideas?
Thanks,
Scott
Sep 22, 2020 13:18:46
System: Service protocol amazon-drive is enabled.
System: Service protocol HTTP is disabled.
Sep 22, 2020 13:17:33
System: ReadyNASOS background service started.
Sep 22, 2020 13:15:51
System: The system is rebooting.
  • Sandshark wrote:
    It sounds to me that PHP5 was remoevd, but this file was not: /etc/apache2/mods-enabled/php5.load.  I'm not really versed in how apache uses such configuration files, but I think it automatically runs anything in that directory, there is no poiner to the file elsewhere that you also need to remove.  Try just moving that file to a holding area and see what happens.
    Since it works in the RN102, /usr/lib/apache2/modules/libphp5.so wasn't removed either (and is the arm version of the library). So PHP5 wasn't fully removed.
    Still you could simply move php5.load.  Make sure there's no php5.conf in the folder either. Also, you should look at the libraries php5.load is loading, and move them to the holding area also.
    Lines 200, 201 in the apache2.conf are
    200  IncludeOptional mods-enabled/*.load
    201  IncludeOptional mods-enabled/*.conf
    So you don't actually need to edit the conf file.
    Still,I'd do the factory reset (painful though it is) if it were my own system.
  • Looks like I ended up in "safe-mode".   What is the proper way to exit "safe-mode"?
    Scott
    • SLK-Purdue's avatar
      SLK-Purdue
      Luminary
      Some additional information.  Any ideas?
      admin@NAS-Ksander-2:~$ systemctl status apache2
      ● apache2.service - The Apache HTTP Server
      Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
      Active: failed (Result: exit-code) since Tue 2020-09-22 18:21:00 EDT; 2h 44min ago
      Process: 23934 ExecStart=/usr/sbin/apachectl start (code=exited, status=1/FAILURE)
      Process: 23852 ExecStartPre=/frontview/bin/fvapps (code=exited, status=0/SUCCESS)
      admin@NAS-Ksander-2:~$ systemctl status apache2-safe
      ● apache2-safe.service - The Apache HTTP Server (Safe Mode)
      Loaded: loaded (/lib/systemd/system/apache2-safe.service; static; vendor preset: enabled)
      Active: active (running) since Tue 2020-09-22 18:21:00 EDT; 2h 44min ago
      Process: 23942 ExecStart=/usr/sbin/apache2 -f /etc/frontview/apache/safe-mode.conf (code=exited, status=0/SUCCESS)
      Main PID: 23946 (apache2)
      CGroup: /system.slice/apache2-safe.service
      ├─23946 /usr/sbin/apache2 -f /etc/frontview/apache/safe-mode.conf
      ├─23947 apache_log
      ├─23948 /usr/sbin/apache2 -f /etc/frontview/apache/safe-mode.conf
      ├─23949 /usr/sbin/apache2 -f /etc/frontview/apache/safe-mode.conf
      ├─23954 /usr/sbin/apache2 -f /etc/frontview/apache/safe-mode.conf
      └─23955 /usr/sbin/apache2 -f /etc/frontview/apache/safe-mode.conf
        SLK-Purdue
        Luminary
        Logs show
        Sep 22 18:21:00 NAS-Ksander-2 systemd[1]: Starting The Apache HTTP Server...
        Sep 22 18:21:00 NAS-Ksander-2 apachectl[23934]: apache2: Syntax error on line 200 of /etc/apache2/apache2.conf: Syntax error on line 1 of /etc/apache2/mods-enabled/php5.load: Cannot load /usr/lib/apache2/modules/libphp5.so into server: /usr/lib/apache2/modules/libphp5.so: wrong ELF class: ELFCLASS32
        Sep 22 18:21:00 NAS-Ksander-2 apachectl[23934]: Action 'start' failed.
        Sep 22 18:21:00 NAS-Ksander-2 apachectl[23934]: The Apache error log may have more information.
        Sep 22 18:21:00 NAS-Ksander-2 systemd[1]: apache2.service: Control process exited, code=exited status=1
        Sep 22 18:21:00 NAS-Ksander-2 systemd[1]: Failed to start The Apache HTTP Server.
        Sep 22 18:21:00 NAS-Ksander-2 systemd[1]: apache2.service: Unit entered failed state.
        Sep 22 18:21:00 NAS-Ksander-2 systemd[1]: apache2.service: Triggering OnFailure= dependencies.
        Sep 22 18:21:00 NAS-Ksander-2 systemd[1]: apache2.service: Failed with result 'exit-code'.
  • StephenB's avatar
    It looks like you failed to uninstall your apps.  While the NAS can convert it's core functions from arm to x86, it can't convert third party apps.
    In your case, at least one of the apps uses php5.
    Options are to
    1. do a factory reset, reconfigure the NAS, and restore from backup.
    2. try putting the disks back into the RN102, and migrate back.  Then uninstall the apps, and try again
    I guess you could also try uninstalling the apps now (either from the web ui or from ssh) - no idea if that will work or not.
    Definitely make sure you have a backup, no matter which option you attempt.
      SLK-Purdue
      Luminary
      First, thanks.much.
      I was pretty sure that I uninstalled but I have now migrated back to the 102 and confirmed that all apps were uninstalled.   What points you to php?
      I am back running fine on the 102.   Any other thoughts?  Seems the issue is somewhere in the change for arm to x86.   I really want to get the the 312.
      Scott
      Options are to
      • StephenB's avatar
        This log entry you posted:
        /etc/apache2/mods-enabled/php5.load and /usr/lib/apache2/modules/libphp5.so don't exist on a stock OS-6 system, so php5 was installed by an app. Given that you did uninstall the apps, it sounds like one of your apps didn't remove php when it uninstalled.
        Well, I gave you the options that I see.  You could do the factory reset and restore the data - that is best done on the RN312, not the RN102. That also gives you a fully clean install (and if the RN102 is old, it likely will give you better performance).
        Or you can attempt to uninstall php5 on the NAS using ssh.  You'd log in as root, using the NAS admin password.
        A command that might do it is
        apt-get autoremove --purge php5
        I say "might" because I haven't actually run this myself.  As always, you use ssh at your own risk.
        If it does complete successfully, then reboot the RN102 just to make sure the web interface works properly before you move back to the RN312.  Maybe also check that the two files above are gone.
ProSupport for Business
