Teppic
Jun 16, 2014Aspirant
Strange Power Behaviour in ReadyNAS Pro
Howdy, I have a ReadyNAS Pro Pioneer (RNDP600E), now about 5-years old, and it has served me very well and faithfully. It's had some hard drive upgrades in its life and all has been good. Yester...
gsuttor
Nov 04, 2015Aspirant
Sorry to rebirth an old thread but I'm looking for a list of compatible PSU's for my old ReadyNas Pro Pioneer.
List = More than 1 so I can find some!
Does a list exist? Can't seem to Google find anything.
Next stop will be ripping it out, measuring up and guessing on a replacement, which I'm not keen on the guess part.
Nov 04, 2015Guru - Experienced User
A Seasonic SS-300SFD is the usual replacement, best purchased with an 24 pin extender cable.
Any SFX power supply will fit; you want 3 4 pin molex connectors.
- gsuttorNov 10, 2015Aspirant
Hard to find that exact brand and model locally. posting my progress for the sake of others searching.
Sourced a Silverstone SFX 300W and got the 24pin extender cable but..... It only had two molex connectors... Arrggghhh.... Didn't read you post close enough that I needed 3. So I can get a $5 SATA male to Molex female power converter for the extra needed but hard to find locally as well. The extra (non modular) cables are also a bit of a mess and hard to fit in the chassis.
I should not have rushed my purchase before closing time for a weekend upgrade.
After longer consideration, the 450W 'modular' PSU probably would have been easier to manage on the cable side of things with the same SATA to Molex converter.
needless to say the noisey, 15min to start up PSU is back in till I get a connector next weekend.
- SandsharkNov 10, 2015Sensei
You should be able to remove the Molex connectors from the old one and install them on the new, converting one SATA in the process. I did that with all of them and cut the length down in the process. For the extras, just cut off the unneded wires and put shrink wrap over the exposed ends to keep them from shorting to anything.
Of course, this voids the power supply warranty, but it makes for a cleaner installation and, I suspect, retains proper airflow better.
- gsuttorNov 11, 2015Aspirant
Good advice, this is kind of beyond my ability (well not done before) but willing to attempt if I can't find the adapter. Thanks.
