Digsy
May 07, 2014Aspirant
Swap drives from ReadyNAS Duo V1 to ReadyNAS 102
I'm about to buy a new ReadyNAS102 and to cut a long story short I'd like know if it is possible to simply put the drives from my Duo V1 straight into the 102? Long version: My Duo V1 has 2x 1TB mi...
May 09, 2014Guru - Experienced User
If you are going to reset the duo in step 8 anyway, there is no point to steps 2 and 3.
