pfrom
Mar 27, 2015Aspirant
system enhancement 2nd hd
i installed a new rn 104 as one disk System with disk seagate st4000dx001-1ce168 ther are no Problems it works all perfect. i use the x raid 2 volume now i want to enhance with a second disk sa...
Mar 28, 2015Guru - Experienced User
It used to be that way, but i believe OS6 added a format step because too many people assumed their NTFS-formatted disk would be preserved (and lost data).
vandermerwe wrote: If you just stick the disk in with the nas on it should be formatted by the nas, regardless of how it is currently formatted.
In any event, you can just insert the disk as vandermerwe says. Then check the volume tab of the web admin GUI (selecting the new disk). If you need to format, the format button on the right should be enabled.
