dmitrof23
Oct 16, 2019Aspirant
System volume is full
Hello. There was a problem that the web interface does not save the changes made (for example, does not even change the date and time). When connecting through the console via the COM port, even auth...
- Oct 16, 2019
You can try logging into tech support mode, and then sort out what's taking up the space in the OS partition.
After booting in tech support mode, you use telnet to connect; using root as the username and infr8ntdebug for the password.
After that
# rnutil chroot
which will start raid and chroot.
if the OS partition isn't mounted (not sure, as I haven't done this in a while), you can mount it with
# mount /dev/md0 /sysroot
dmitrof23
How to enter technical support mode?
Marc_V
Oct 16, 2019NETGEAR Employee Retired
Welcome to the Community!
If you have the ReadyNAS 3200 you can follow this guide on booting the NAS on Tech Supporrt mode.
https://kb.netgear.com/24868/How-do-I-access-the-boot-menu-on-my-ReadyNAS-3200-4200
HTH
Regards
- SandsharkOct 16, 2019Sensei
You cannot log into the cosole with the admin account, only as root (using the admin pasword).
