Suires
Mar 18, 2019Aspirant
System volume root's usage is 82%. This condition should not occur under normal conditions. Contact
I have two ReadyNAS 104 on my home network.
Today I received emails from both of them with this error.
"System volume root's usage is 82%. This condition should not occur under normal conditions....
Suires
I think I fixed my own issue by following the 2 posts below:
It's definitely caused by clamav tmp files. I am just not sure if I should disable the antivirus though.
- antinodeMar 18, 2019Guru
> I have two ReadyNAS 104 [...]
You've posted this in a "Cable Modems & Routers" forum. You might
find more information and people who care in some appropriate forum,
like, say, something under:
