drc-ravi
Aug 14, 2020Aspirant
Temporary files getting created all over the place, ReadyNAS 312
Hi Everyone I was using my RN312 as a backup solution, untill COVID-19 happened. Due to my limited staff size - I decided to make it my primary file server and used a WD NAS as the backup solutio...
- Dec 20, 2020
Sandshark Hey! Just an update - since you took the time to help me with my problem, I thought I should update you on this. I recently updated the firmware on my RN312 from 6.10.3 to 6.10.4.
And guess what - the problem that I had with Temporary files getting created, got solved!! I had tried fiddling with various permutations in the settings, but to no avail. And here come a new firmware - it solves by itself. And I was hoping there would be some mention of this issue in the release notes of the new firmware, but Nothing!! I guess they didn't want to admit that fault in particular.
Anyway, happy that I don't have to deal with that problem anymore. And thanks again to you for trying to offer a solution. Cheers!!
Sandshark wrote:While it does not contain a solution (and I still know of none), here is a long discussion about this issue: Showing-tmp-files-in-ReandyNAS-424. If you right-click on the files in Windows Explorer and select Properties and then the Details tab, who does it show as the owner of the files? Specifically, is it always one user, different users, admin, or root? If always one user, is that user the share owner?
drc-ravi
Dec 20, 2020Aspirant
Sandshark
Dec 20, 2020Sensei
Thanks for letting everyone know. It may not have even been an intentional bug fix in 6.10.4, maybe coming as a positive side effect of another change.
