aalexandrebeta
Feb 09, 2017Master
Theoric HDD limit acording to devices
I'd like to know what are the limits acording to protfolio devices?
- Feb 09, 2017
aalexandrebeta wrote:
What HDD max capacity is it possible to install acording to the type of devices?
RN series, legacy, etc......
The limits I know about:
4.1.x (duo v1, nv+ v1, etc): 2 TB disk limit
4.2.x: (ultra, pro, etc): Some rackmount models have a 2 TB disk limit in some slots. Otherwise, no known limit on disk size, but there are limits on volume expansion. A volume can't expand over 16 TiB, and it can't expand more than 8 TiB from its starting point. Volumes over 16 TiB can still be created on 64 bit plaforms, but 32 bit platforms (NVX) have a hard volume limit of 16 TiB.
5.x (duo v2, nv+ v1): No known disk size limits, but the same volume expansion limits of 4.2.x.
6.x (RN10x, etc): No known disk size limits, and no known volume size limits on any platform running firmware 6.4.0 or newer. ARM models have a limit on the maximum iSCSI LUN size (8 TB).
aalexandrebeta
Feb 09, 2017Master
What HDD max capacity is it possible to instal acording to the type of devices?
Feb 09, 2017Guru - Experienced User
- aalexandrebetaFeb 09, 2017Master
StephenB You nerd rocks a lot, thanks!!!
Have a good day/night whatever :) :) !!! :; !
- StephenBFeb 09, 2017Guru - Experienced User
Day at the moment (and snowing like crazy here in Boston). :smileyhappy:
If you have enough snow send some to FrogLand AKA France :)!
