Retired_Member
Apr 21, 2019Three different Linux/Debian releases running on three different type of ReadyNAS
Dear Netgear mods, can one of you shed a light on this riddle? It turns out, that on RN524, RN426 and RN204 three (slightly) different releases of Debian are running.
See details here: https://...
- Apr 22, 2019
Retired_Member wrote:
So, to my understanding the processor family and the update method make the difference. Any comments?
Just the processor. Both my RN102 and RN202 are set to "stable", and I see the same version strings that you do.
Note you can also see these strings with ssh using
# cat /proc/version
Retired_Member
Apr 21, 2019To make things as much comparable as possible I downloaded the logs from all my three nas a few minutes ago and I find the following:
(1) In kernel.log for RN426 on 6.9.5 Hotfix1 Update method: Long-Term support
Apr 22 01:23:15 nasname kernel: Linux version 4.4.157.x86_64.1 (root@blocks) (gcc version 8.2.0 (Debian 8.2.0-12) ) #1 SMP Wed Dec 19 09:35:08 UTC 2018
(2) In kernel.log for RN204 on 6.10.0 Hotfix2 Update method: Stable
Apr 22 01:23:00 nasname kernel: Linux version 4.4.163.alpine.1 (root@blocks) (gcc version 8.3.0 (Debian 8.3.0-2) ) #1 SMP Wed Mar 20 18:04:34 UTC 2019
(3) In kernel.log for RN104 on 6.10.0 Hotfix2 Update method: Beta
Apr 22 01:31:13 nasname kernel: Linux version 4.4.163.armada.1 (root@blocks) (gcc version 4.6.4 (Marvell GCC release 20160226-c4af733b 64K MAXPAGESIZE ALIGN) ) #1 SMP Wed Mar 20 18:11:54 UTC 2019
In the kernel.log of (3) the string "debian" is not even found at all.
Kind regards
- StephenBApr 22, 2019Guru - Experienced User
# cat /proc/version
- Retired_MemberApr 22, 2019
Thanks for the hint, StephenB, I'm downloading the logs on a regular base, anyways.
Kind regards
