alsalmioxy
Oct 29, 2016Aspirant
To select the right ReadyNAS for my Axis Camera
Hello everyone!! I'm new to ths form.
I need to buy ReadyNas for my Axis cameras and I have different brands of Axis like P1405-LE/ P3214/ M3046-V and also some other Brands like Dahua and Hikvision. I'm not sure which one will fit my Axis Cameras and also can work on the other brands? Would you please give me some options so I can select? Mostly I need 4-bay.
- I have these cameras connected to cisco switch SG300-28PP.
- This is for my home.
- I would like to get different selection from netgear.
- I have around 12 cameras connected to the switch and all of them PoE.
Also do you I need to buy any licenses to connect theses cameras? Or I can configure the cameras once I have the Ready-Nas connected to the switch? I would like to view and control all the system from anywhere like IPad or IPhone using the application.
Thank you for the support -
Are you planning on using ReadyNAS Surveillance? That is a licensed application that you would need to purchase.
Though many cameras have built-in support for writing to NFS or SMB data shares, so you don't necessarily have to use Surveillance.
There is more information on ReadyNAS Surveillance here: https://www.netgear.com/business/products/storage/readynas/readynas-surveillance.aspx
Supported cameras for Surveillance are here: http://www.downloads.netgear.com/files/GDC/RNNVR01L-1000S/ReadyNAS_Cameras_DS_28Feb14.pdf
- alsalmioxyAspirant
Basically I need a storage area to record the video.
I know Axis has their own application which can be installed in the mobile but is it possible to connect this application to the ReadyNas and play back any video?
Thanks.
I'm not an expert on Axis. But if Axis Companion software does what you want, then you could use it with a ReadyNAS.
You'd need to install the Axis software on a PC (which would need to be on 24-7). Then you can mount a NAS network share as a PC drive letter, and use it as if it were local. Axis Companion might also directly support NAS network shares (I never used it, so I don't know).
Their recommendations are here: http://www.axis.com/us/en/support/faq/FAQ115869 A ReadyNAS RN314 meets these requirements (as do the RN500 and RN600 series). WDC Red Pro disks would be suitable; you could also use WDC purple drives which are designed for surveillance.
Though AXIS recommends Intel processors, the RN214 also has enough performance to do this job.
AXIS recommends a UPS - which makes sense for any NAS. You can protect the PC and the NAS with the same UPS if you get one of reasonable size. I use Cyberpower myself, many people also like APC.
