aalexandrebeta's avatar
May 31, 2016
Tray adaptator for SSD
I was wondering if someone can help me in finding a tray to switch from standard HD to SSD for a future NAS purchase.
  • All our current ReadyNAS come with drive trays that can hold 2.5" drives. When using 2.5" drives you will need to use the included screws. Screws are not needed when using 3.5" disks.
  • ssd drives are just the same as 2.5 inch hard drives. any tray that can hold 2.5 inch drive will do
    • mdgm-ntgr's avatar
      mdgm-ntgr
      NETGEAR Employee Retired
ProSupport for Business
