Gary86
Jun 22, 2020Follower
trouble reconnecting to mapped drive RN212
hi, looking for some ideas...
my old readynas died recently, so I got a RN 212. All set up and restored my data fine, mapped the network drives as I did before. I'm having trouble reconnecting to the mapped drives, and I can't figure out why.
When I first turn on the laptop it won't connect- error message is 'parameter is incorrect' it will connect through readycloud or browser, and it shows up on the network (can't connect through the network though). If I restart the laptop it will connect through the mapped drive and the network (file explorer)
I'm running W10 v1903
Everything worked fine on my old ReadyNAS, but I set that up a long time ago and it didn't have a lot of the features of the 212
thanks for any suggestions you might have
cheers, Gary
1 Reply
- SandsharkSensei
I'm unfamiliar with the "parameter is incorrect" result. Did you save the login credentials when you created the mapped drive? I don't, which may be the difference.
As far as the NAS showing up in Network but not being accessible when double-clicked, that's a problem some of us see and others don't. I've seen similar postings regarding other NAS brands, so I think it's a Linux Samba and/or Windows issues, not one Netgear can solve. I hope one day somebody will get to the botttom of it.
The best work-around is to add the NAS IP address to your HOSTS file on the Windows machine. You can Google how to do that. Note that that does require that your NAS always have the same IP address (which is always a good idea, anyway), and that is best accomplished by reserving an address for it in your router than by using the static IP capability of the NAS OS.
