F_L_'s avatar
F_L_
Tutor
Jan 10, 2015
Tv-card ReadyNas Ultra
I´m trying to install a tv-card on the Ultra (6.2.2) for TV-headend to use.
But it seems that the card is not loaded right since its not visible in TV-headend.
The card I´m using is this TrekStor DVB-T USB Stick which should be supported in linux since kernel 2.6.30 according to
http://www.linuxtv.org/wiki/index.php/DVB-T_USB_Devices
I put the latest firmware in /lib/firmware
Is this folder used by the ReadyNas?
Anyone done this before?
ProSupport for Business
