Karoluch
Jun 27, 2011Aspirant
Ultra 2 Plus - not silent
I use NAS mainly for Squeezebox Server. The device is placed in my living room where I listen to the music. I can also move it to the bedroom. In both cases this needs to be quiet. So far I used fanl...
mdgm-ntgr
Jun 27, 2011NETGEAR Employee Retired
What version of RAIDiator are you running? There was a known issue with 4.2.16. Please update to the latest firmware (currently 4.2.17: http://www.readynas.com/RAIDiator_x86_4_2_17_Notes)
Also having two disks installed would allow for better airflow and should mean the NAS would be less noisy.
If using the default X-RAID2 adding a second disk would give you redundancy so that if one disk were to fail you wouldn't need to restore from backup.
